Having a lot of trouble with symbols and wires not snapping to grid. Moving circuits around on a page and they end up not on the grid. Draw a new wire and it doesn't snap to grid. If I drop a new symbol it will go to the grid.
Hi Lisa,Have you tried to snap grip from here? (refer below image)
Avanti
Hi Avanti
I doesn't matter what that is set to the issue is it is not snapping to the grid.
Hi Lisa,Can you try to toggle snap grid option,\
Hi Lisa,IN the earlier post I had mentioned that this is an existing BUG#609600 and had provided below Work Around to try. Can you try the workaround for now and let us know if it helps with the issue you are facing. 1. Select the symbol that needs to be copied.2. Next point the mouse cursor to any connection point or part of the symbol such that this point will be the insertion point when placing the symbol.3. Next do Left Click and Right Click in the mouse at the same time and you will see a Cross Hair indicating the point that has been selected as reference for pasting, now do Ctrl + C to copy.HTHRegards,Satish Saptasagar
