I have a project with 40 pages. I have a situation here, now i have to rename all the pages, is there any way that all the wire numbers to get updated? I have wire sizes added already and now i want only the wire number to get changed wrt page number. Please help me if there is any solution to update wire numbers with page numbers?
Hi Madhavi,You can add a page number variable to the Wire Number Text which will add the details of Page Name. You can do the same from Project Manager >> Options >> Wire Settings >> Label Preference >> then add your prefered variable to the Wire Number expression as shown in the below image.
HTHRegards,Satish Saptasagar
I have this expression already set in my pc, but still when i rename the wire number the wire number is not getting updated.
Hi Madhavi,If you Run Automatic Wire Number again then you will see that the wire number will change. When a wire number is assigned it is maintained even after the page is renamed becase there might be another page with the same name but in a different drawing set. Due to which there might be possible wire number duplication if the wire number is directly updated, hence this has to be done manually after the page number is changed so that the other pages are not affected. Let me know if yo need more details on the sameHTH Regards ,Satish Saptasagar
