We are testing OpenUtilites Substation connect update 10. It is possible to use it with a local SQL database. But in production environment it is better to use a SQL server.
We tried to connect to a 2016 and 2019 version of a SQL server, without any result. The error is: "The database is not compatible with the product you are using and cannot be specified".
Are there any settings important during the setup of the SQL server?
HI Gunther ,Can you check Compatibility chart ,
Avanti Khandalkar
Hi Avanti,
As I read this. Does it mean I cannot use the SQL server on a network but only on the local machine? Is the database not being used by other members in the team working on the same project/data?
HI Gunther,You can use an SQL Server on a network. The database can be used by other members of the team. You need to configure it.Regards,
Avanti
