if i open tools , and dock a toolbox (i.e. Snaps) to the side of the screen, if i close and reopen promise, the docked toolbox disappears.i'm using Promis.e connect version 10.05.00.38 update 5.
anyone know how to keep these setup between sessions
many thanks
Hi Jason,Which Tool Box are you facing the issue with? Also, have you tried accessing the Tool Box from File >> Settings >> Tool Boxes>> Select the Tool Box according to your requirement and then try docking it ? Hope this suggestion helps !Thanks & Regards,Satish Saptasagar
Hi Satish,
one of the main ones we'd like to use is the main tasks
if we turn it on, when we reload promise we have to select another from the dropdown, then re-select "dialog", to have it come back
many thanks for your input so far
Hi Jason,This issue you are facing is an Exiting BUG#699304 and it might be fixed in the future Promis.e CONNECT releases. You can refer to the below link for Promis.e Release Information and the issues resolved in the releases.
