pur dept has recently upgraded from Promis.e V8i select series to connect
and i have some text on a symbol that won't delete.
when i look at the symbol, that text is not shown,
but there appears to be a duplicate attribute.
i've attempted to change duplicate attribute status to hidden but nothing happened.
the original symbols were created using Promis.e V8i select.
is there anything that can be done or is it a redraw in promis.e connect
Hi Jason,Since you have mentioned that the symbol was created in Promis. e V8i, can you let me know the specific version of Promis.e V8i that you were running before upgrading to Promis.e CE?Also, can you share the screenshot of the PLC Attributes like in the below image? Thanks & Regards,Satish Saptasagar
It's bentley v8i select series 3
i didnt see the attribute, in the list of attributes, and now promis.e has crashed so can't check.
Hi Jason,If your earlier version of Promis.e was V8i SS3. Then you will have to migrate your projects catalogs and to Promis.e SS7 and then migrate them or use them with Promis.e CE. Below is the Wiki Link that will provide more details on your migration. Let me know if you have any questions.
Answer Verified By: jason good
apologies, we were on select series 7 for promis.e .
(we were on bentley microstation select series 3) ...my mistake.
Hi Jason,Can we take this issue related to Migration offline and discuss it via SR? We can also have a meeting to discuss the issue. Regards,Satish Saptasagar
