I think due to a large number of projects within our database, the configuration assignment utility can take a very long time to load. Is it possible to update an older SS8 project to connect edition manually without using this utility?
It appears the Ect.fid file is being updated, but is there anything else that gets updated?
Hi Adam,The configuration Assignment Utility also adds Promise_WorkSpace.cfg that contains information on the WorkSpace and the WorkSpace associated with the Projects. Hope this helps!Thanks & Regards,Satish Saptasagar
Answer Verified By: Adam1V
This has worked, many thanks Satish Saptasagar
