hello Everyone, i am using remote dekstop for promise_e . i could not able to open Print orgainser. when i select the print organiser the window is not open to select files for print. when i click simple print or ctrl+P than window is pop up. for multiple print it is very difficult without print organiser.
Hi Gaurav,For the issue you are facing can you try doing Reset Dialogs on your machine and check if it helps? You can follow below Wiki Link for steps.
Also if the above suggestion does not help can you try performing restore defaults on your machine, you can follow the below Wiki Link for the steps.
Thanks Mr.Satish
2nd option worked.
