working with open utilities connect edition. Create Symbol Command fails to open the application. everything works. Believe there is some sort of disconnect between main program and this command??? Any suggestions?
Hi Larry,Is there any error message? or its just fail to open.
Avanti Khandalkar
Just fails to open....rebooted several times. worked fine up till today
but I am now wondering if a recent Windows 10 update affected it?
No, I dont think so, Can you try to restore platform default?
