symbol text randomly not displaying.
I've checked and turned on all levels as seen in screenshot 1 & 2.a check of the symbol connection points shows the data ( screenshot 3)and if you go to modify the symbol , you can see that the connection point text is displayingas we expect it to (screenshot 4)
we're also finding this error on some layouts where entire layout symbols suddenly will not display.
when we've checked on our servers , the previous versions (sometimes even 2 hours prior, showseverything, but something is happening without user intervention which is causing symbology or parts ofsymbology to NOT DISPLAY.
Hi Jason,Can you check in the DGN where you are not able to see if the "Display Connection Point Text" is active? It can be verified from by following details in below image to turn on the option.
If this options has been turned off by any user, changing the visibility from the level manager will not toggle on the display. Kindly let us know if the above suggestion helps with your concern. Thanks & Regards,Satish Saptasagar
