Until recently when I opened my folder structure it always displayed in alphabetical order. It recently changed to a random order and I can see no way of getting it back. Has anyone seen this or have a fix for it? Thanks
Hello George,Can you let me know the version of Promis.e CE you are using? Also can you check if Resetting the Project Manager helps with this concern? you can follow the below Wiki Link for the steps to reset the Project Manager.
Resetting the Project Manager did not work.
Hi GeorgeAre these projects located on local machine or network location? If they are located on network are you using a Mapped Network path or a UNC path in the configuration? Thanks & Regards,Satish Saptasagar
Satish,
Thanks for assistance.
They are networked, and using mapped path
