When making the regions for the panels and their connections from the region tools, deleting the region in panel layout mode did not remove them within the edit region connections function. I can't find how to remove them because they also appear on all pages when entering the function to edit region connections.
Hi Damian, After you delete the Region from the Panel Layout page select the Update Page command before opening the "Edit Regions Command". You can access the Update Page command from Manage >> Update Page under the Maintenance section. Thanks & RegardsSatish Saptasagar
Satish, thank you for your reply.
I did but that didn't resolve. I also rebuilt the database but got no results. I mean, I still have the problem.When I update the page, I get the message "regions should not overlap with each other"
Damián Pavón
I had a few questions as below >> On the page where this Error message is seen do you see and Regions that are over lapping? >> Can you try using Validate page and then confirm if you get any message? Looking forward for your update. Thanks & Regards Satish Saptasagar
Satish,
When I select validate page the same message appears. and there is no region in that place. It's like a wrong message in my opinion.
It also appears when you enter the page.
Damian,Can you upload the project backup on the below link so that I can investigate the issue? https://bentley.sharefile.com/r-r302bf905c99b4bb3b3f9f04150fcf493Thanks & Regards Satish Saptasagar
