I would like to add keyboard shortcuts for the things I do the most in Promis.e. I see where I can change function key and other keyboard shortcuts, but where do I find the list of text commands to assign? I saw a reference to "Microstation Key-in List", but am unable to find that list.
Also, does this list include items from the RMB (right mouse button) menu? I would really like shortcuts for things like Device Properties, Modify Text, etc as I seem to do this 1000s of times per day.
Thanks in advance!
-Brad
Hi Brad, You can activate Keyboard shortcuts using the F2 key, it will reveal the keys that can be used to navigate trough the different menus and tools in the Ribbon Tool Bar.
Hope this helps Thanks & Regards Satish Saptasagar
Thanks for the reply. Yep, I had found the F2 feature. I'm looking for a way to assign a short-cut key (like F7, or CTRL-D, etc) to items on the right-click menu, like this Device Properties or Symbol Text.
