Can someone recommend a self-directed learning path for Promis.e?
I have found the following:
Promis.e_CE_Quickstart Promise_CE_Fund_Metric_Dataset Promise_CE_Symbol_ANSI
They seem a bit dated in that default parts databases aren't quite right. Also, the self study workbooks do not seem to use the Work Space page in the Promis.e program.
The drawing files included in the download have all the correct parts described in the workbook PDF. Is there a way to take a part in a drawing and save it into a parts database?
Or is there a link to an updated self-study course for Promis.e?
Thanks very much
Ralph
Hello Ralph, You can try the below link to our Learn Server where you can try to find videos which can help you with Promis.e CONNECT. Hope this HelpsThanks & RegardsSatish Saptasagar
Over last couple of weeks most of the Promis-e and OpenUtilities Substation learning paths are no longer available. Once you search and click on the desired course you now get message "There are no courses that meet your criteria. Please change your selection to try again." Message =>>
Hello Geoff, I can see that the Learning Paths are available for Promis.e. I searched using the below filters. Were you trying to search for any specific Topic?
Hope This HelpsThanks & Regards Satish Saptasagar
Hi Satish,
I get the same search result/outcome as you, however the problem is when you click on a course you cannot access, returns below message.
50% of the Promis-e and OpenUtilities Substation course are no longer available when they were a couple of months ago.
Hi Geoff, This might be happning due to the reason that you might be trying to access the V8i Courses, please apply one more filter of Generation = CONNECT and you will find the available courses.
This should solve your concern I believe.
Hope this helpsThanks & RegardsSatish Saptasagar
No luck with your suggestion. Result returns no training courses available, about 6 weeks ago myself and whole AECOM community globally had access, something has changed?
Thank you
Geoff Beck
