Hello everyone, I would like to do the following. See height of levels as a reference through my 3D model pages. For example, level 0, ceiling, 1st floor, PAT mesh depth, etc. To have references from certain points, for example, something similar to what Revit has. Can it be generated?
Hi Damian, You can use the Dimension Ordinates feature which is a MicroStation Power Platform tool. It can be accessed from Drawing Workflow >> Annotate. You can refer below Video for more details. Let me know if this answers your question. Thanks & RegardsSatish Saptasagar
Thanks Satish, The question was if it is possible to restrict the height of the walls, for example, to the levels created. I also made the query in the MS forum and it is not possible, not even in OBD.
