I am generating a report with one data field of a list of wire numbers. I want to insert two blank rows every 80 lines and am guessing this can be done with a script. I can figure out how to do this with the vba macro in excel shown below, but am not quite sure how to translate this to a report script so this can be done in one step.
Hi Scott, Have you tried converting this script to C# and then using it in Script section of the Report template Designer?
Hope this helps Thanks & Regards Satish Saptasagar
