Windows 10 :
C:\Users\(current login)\AppData\Roaming\Bentley\Promise
Alternatively:
%APPDATA%\Bentley\Promise
Question:
USING THE ABOVE INSTRUCTION I HAVN'T FOUND PROMISE IN THAT FOLDER. PLEASE COULD YOU ASSIST FOR, I AM SUFFERING.
SO HARD TO OPERATE WITH OUT RIGHT CLICK TOGGLE..
Hello Aqib,For the issue you are facing, can you try the steps in below wiki link and check if it helps? the link details on deceasing the Right Click time since in Promis.e CONNECT you need to do long right click for Right Click menu.
Hi Satish,
again, disappointed that i followed all your instructed ways but couldn't find the "Promise" i used several search methods to somehow track it down but. it doesn't exist.
Thank you for trying help me out... moreover if you have any other solution let me know .. appreciate it for.
Hi Aqib,I have a question below question which are needed to further investigate the issue. 1. Can you confirm the version of Promis.e that you are currently using? 2. The issue you are facing is it a fresh installation of Promis.e? 3. Since you have mentioned that the folder Promis.e is not there in "%APPDATA%\Bentley\Promise", hence have you tried reinstalling Promis.e? usually if these files are not created then there might be installation file corruption. Thanks & Regards Satish Saptasagar
Hello there,
I got it I guess it wasn't installed ever. so kindly would you recommend me from where i can haver installation setup.
Hi Aqib, You can use the below link for details on how to download Promis.e CONNECT.
