using a star point connection , doesn't display the connection references, despite being able to correctly navigate to the other ends.
Hi Jason,Can you right click on the Wire Link check >> select Wire Link Usage and check if all the wire links have same Star Group Index or different? If the Index of the Star Group is not same then you can navigate to Wire Link with same Wire Link Id but different Index number. Can you confirm if this is the case on your side?Thanks & Regards Satish Saptasagar
please see attached, the wire links are correct and will navigate but will not display correctly until after i've gone into the wire usage (making no changes) and just selecting OK, once the wire usage dialogue box closes the wire link ID updates
Answer Verified By: jason good
Hi Jason, For the second screen shot that you have shared I can see that the "Wire Starting Point" check has been ticked for both the Wire Link symbols. Please uncheck same for one of the Wire Link symbol and then check do an Update Page to check if it fixes the issue? Below is a screen shot of an example from my Promis.e. Hope this Helps!Thanks & Regards Satish Saptasagar
