Hello everyone,
I need help with an installation. The following message appears when the installation is about to finish
That could be happening?
It should be made clear that the client already has other Bentley solutions
Hi Damian, On the machine where this issue happens does the user trying to install the software have the Admin Permission on the local machine? Also can you try installing OpenUtilities Substation again and while installing select Configure and uncheck the "Microsoft SQL Server 2016" as highlighted in the below screen shot and then try installing? After the installation is complete try installing the SQL Server Express separately. Below is the link to download SQL Express 2019 but you can download any version as per your requirement from the Microsoft Website. Let me know if the above suggestion are helpful with your concern. Thanks & Regards Satish Saptasagar
Thank you very much Satish, two questions about it. The first is what happens if you are not the administrator? And the second is if you are going to have to enter the application, but after having SQL server installed. These services are what the client has.
If you are not an administrator on your local machine then it has been observed that it causes issues with installing SQL Server since it needs access to folders in C: that admin on local machine has access to and if it is not available or the permissions are not present then the installation might not complete or might not install correctly. Yes you can fully access the application after you have installed SQL Server and or configured it with the SQL Server after creating the Project Database.
So running with as administrator would be enough?
