Generate Project in OUS to AutoCAD
How are you, I ask you a question, the contractor demands to use AutoCAD 2022, for the development of engineering. How viable is it to carry out the engineering with Substation and export to DWG, seeking to save time, and that this whole process does not generate more time than it can be done directly in AutoCAD. I hope the query has been understood. Thank you
Parents Reply Children
