I am working on drawings for our shop and they use inches and feet. Their measurement tools are in fraction formats such as 1/8" 1/16" 1/32nd" I need to have my dimensions listed on the panel drawings in this format. I can't figure out how to convert from one style to another. Any ideas?
Hello Anna, You can achieve that by changing the Dimension Style of the Dimension Element.
Steps: 1. Go to Drawing >> Annotate >> Click on Dimension Element. 2. Click on Dimension Styles. 3. Select the Dimension Style that you are using and change the Accuracy to fractional Accuracy's depending on your requirement. Hope this helps!Thanks & RegardsSatish Saptasagar
Answer Verified By: Anna Johnson
