Publishing Document
I have no problem with publishing the document, but I want to know if there is any possible way to make the document clearer when publishing. Whenever I publish in A3 format, the document will not be very clear when zoomed in. Is there a better way to publish so that I can view the entire document more clearly when zooming in.
