Adding UL number to PDF sticky notes in Project Publisher
Does anyone know how to add UL information to a panel drawing?  I have been investigating this and if I do have the information in our database, which could be pulled in by part number for use by promis.e.  I can't figure out how to pull this UL information from our database and add it into the options on the configure section of project publisher.  The field is listed in the parts database under unmapped.  If I can get this information seen by the parts database, I can have this information pulled onto the "sticky notes" for the parts on my panel drawing.  Can anyone tell me how I go about mapping this field so it can be pulled into the project  and I can select it on the publishers configure page?
Anna
  • Hi Anna,
    Try following the below video steps and check if you can add the Unmapped Parts Database column to Parts Database Manager.
    Hope this helps!
    Thanks & Regards
    Satish Saptasagar
  • As seen in the video added a unmapped column to database record. My question is can we rename user4 to example SAP Code ?
  • Yes you can do the same Parts Database Mapping you can refer to details in below Wiki Link on Parts database mapping in that towards end when after Default Mapping button you can modify the details for user4 field before finishing.
    Product(s): Promis.e CONNECT Version(s): 10.00.XX.XX to 10.05.XX.XX Environment: N/A Area: Component Management Subarea: Parts Database Background…
