[U13] Copy/paste child device not working as expected
Steps to follow:
1. Insert device with assigned family - child.1, CPs 1,2
2. Copy/paste (CtrlC/CtrlV) with Maintain Device ID as COmplete
Expected behaviour after paste: child.3, connection point 5,6 as definded in family
Real behaviour: goes to child.3, but connection points are copied from child.1 and overrides that one from a family.
Trying to change to child.5:
- gets correct CPs from family AND child.3 reverts to family values.
Tested on freshly installed U13 on custom symbols/families imported from v8i. But the same behaviour for IEC-2.3 catalog, symbol K3, family 13.
But for terminals (also with family assigned) seems to be OK:
Promise U13 10.03.00.49
Regards, Wojtek
  • Hi Wojtek,
    As discussed in the Service Case email this issue has resulted in BUG#1233038 and workaround for the issue which you are already identified and user is as seen in the below Video.
    Thanks & Regards
    Satish Saptasagar
    Answer Verified By: WojtekM
