DELETE MULTIPLE PROJECTS AT ONCE
Hi
is there a way to delete multiple projects after backing them up.
as previously mentioned , we had 300+ projects. they've all been backed up now
but wonder if there's a way to delete multiple projects at once, or does each project
need to be removed individually ?
many thanks
  • Hi Jason,
    For safety reason there is no function to delete multiple projects at once, you will have to delete the projects one by one.
    The Work Around for this issue would be to delete the projects from the location where the files are present. If you are deleting all the project in a Database then you can delete the SQL Database as well (Check with DBA, project managers if there are any other projects in some other location that might be connected to the same Project Database that might be impacted).
    Hope this helps
    Thanks & Regards
    Satish Saptasagar
