promis-e moving wire object problem hopefully with image
I'm using promis-e with autocad.
I'm moving ojbects wires, wirelinks etc. as one group with the normal move command.
Like as below if i was to move everything from X20:13 to X20:12. I have to assign wire numbers manually. When I do this the wire seems to think it's still connected to X20:13. So when I duplicate the wire number appears in mid air inline with X20:13.
If I try to add a new wire connection to X20:13 and add a wire number. For some reason it thinks it's connected to the wire connections previosly connected to X20:12. So I add a wire number to the new connection at X20:13 it changes the wire numbers on the wires now connected to X20:12.
Does anyone know how to fix this, is there something wrong with my move command, my block, wire connections etc ????
