Hello!
I have a problem with filtering (either quick or build a filter) in DataManager 08.11.08.123 . After applying the filter the top of the view displays ''"filtered..." but the displayed view will not be the filtered one. If I try a Data Sheet on the filtered view it defaults to first tag on the list regardless of which tag is selected initially for the Data Sheet.
I can reproduce the issue on different projects in the 'central' database. The issue is valid for our custom views an for Bentley default views.
Testing a project not part of the multi-project database: filtering has the same behavior but DataSheet selection is on the correct/selected tag
The setup is multi-project database SQL express 2005, Office is 2007
Am I doing something wrong or it is a known issue?
Adam
Problem solved thru tech support.
Could you please post the solution to this issue?
