Placing cable issue
Hi everybody,
I've come across another issue (it seems that I am kind of unlucky, but at the end it is ok, I learn them all, step by step, with your help); the project I am working on, is set-up in real world coordinates (the real North is different than plant North, too).
When I am trying to place a flexible cable, only the centerline of the cable is shown, the body is missing. However, if I move the symbols connected by the flexible cable, close to point 0,0,0, the cable is shown correctly. Is this a known issue? What options do I have?
The rigid bus behaves correctly in both situation, it seems that only the flexible cable is affected.
Thank you very much,
e.g.
