I have added vehicles to my model and added annotation paths both my adding traffic and by single vehicle path annotations. I am able to control speed and key point pauses etc. Is there a way to setup traffic vehicles to avoided other vehicles. Just want to make it so vehicles do not randomly run into and through each other in my annotation. I can create short clips that do not show collisions, but any extended looping of the animation eventually has collisions. It would be great if there were a collision buffer setup say keep all vehicles 10FT from each other then be able to toggle it on or off. Trying to create an intersection animation. I can make vehicles stop and go to avoid one but when looping eventually the timing would be different.
Hello Mike,
Very sorry for your inconvenience. It seems like there is something I couldn't be able to understand.
Did you try with to have a pause in the created path?
Perhaps, can you share the file or a scene to investigate it at our end?
Thank You.
Pinky Shee
