Hello Good Bentley Community
I just wanted to ask how can I change the relative elevation of floor, in order to be able to add underground floors (for parking or something similar)
When I try to do it it doesn't allow me to do so.
Best Regards
Rafael
Rafael,
It works in CONNECT Edition - Version 10.00.00.154.
Also in SS6 - Version 08.11.09.866
Make sure you are setting the negative elevation in the Elevation field, not the Relative Elevation field. Relative Elevation will adjust accordingly.
HTH,
Larry
Hi Rafael,
Did you remove the previous ABD CONNECT before installing the commercial release?
See CONNECT Edition - Preparing for Installation and Configuration for more information.
Marc
